Andehh Posted May 9, 2023 Posted May 9, 2023 We had an issue with some AC pipes that meant we had to cut 3 x MVHR 90mm pipes to access them (AC pipes tucked tight above them) I now need to re-join the 90mm MVHR pipes. Does anyone know the name/link to where I can find three male to male fittings, that will not be blown off if the air pressure gets too high!? Many thanks,
crispy_wafer Posted May 9, 2023 Posted May 9, 2023 (edited) 90mm straight coupling mvhr - Google Search Find ones that have clips inside, you may also need rubber sealing rings too, sorry these are Female fittings, but could for you? Edited May 9, 2023 by crispy_wafer Female fittings not male
