airtightness/insulation and consumer unit
New build in 2022. Consumer unit is in a single storey utility room(off kitchen) that has a pitched roof. This is connected to the 2storey house. From the consumer unit the wires run up in trunking into the ceiling of the utility. A section of the ceiling board was just cut out and obviously a noticeable breeze in coming down(the hole in ceiling board)from the venting which is in the soffit vents.
1)Is this an acceptable way to bring wires by just cutting a rectangular hole and not attempting some form of airtightness/insulation to minimise the breeze coming down the hole in ceiling board?
2)can rockwool type insulation be placed to fill the hole and reduce the cold/breeze coming in?
3)Can rockwool be put throughout the trunking ?
3)any other comments/observations worth noting?
See attached pictures
Edited by irishhouse
spelling
  • irishhouse changed the title to airtightness/insulation and consumer unit
 I wouldn't get too upset, as most trades know little or nothing about airtightness, in fairness.
To solve this, all you need is a squirt of Illbruck 330 foam and it's job done ;)  10 minute fix.
