BadgerBadger Posted March 5, 2023 Posted March 5, 2023 We've just laid out all our posi joists on our masonry build. There are multiple spans which land on internal masonry load-bearing walls. The mitek details specify the gaps between joist bearings should be infilled with masonry to the underside of the floor for lateral restraint, all self-explanatory. But, should I be building up all the other internal wall masonry to the underside of the floor deck, or leaving them down at the bottom of joist / ceiling level?
nod Posted March 5, 2023 Posted March 5, 2023 You should build them up Leaving one clear in each room (If possible) for services to pass through 1
