I'm about to order the bits needed for our Utility and W/C plumbing. Does my plan sound right to you?
Water Supply;
- Existing 22mm HEP (hot and cold) running in ceiling for bath in bathroom above.
- 15mm tee into for washing machine
- 15mm tee into for toilet
- 10mm tee into for basin
I've heard that the washing machine and toilet should be plumbed in before the multibloc valve, is that correct? Doing so would be more of a faff (or not as easy as just teeing into HEP)
Waste;
- new 110mm stack for toilet
- 40mm Y-shaped drain for washing machine + tumble dryer drain, with trap, feeding into new 110mm stack
- 32mm condensate pipe from MVHR feeding into washing machine 40mm, before the existing trap, that goes into 110mm stack
- 32mm drain for W/C basin, with trap, feeding into new 110mm stack
Edited by jayc89
