mjsx Posted February 19, 2023 Posted February 19, 2023 So I recently replaced a structural wall with an RSJ. All fine except some of the wooden joists are not actually resting on the RSJ. This is sort of expected in that the RSJ is perfectly level but the wall that was there before was not but it’s a bit strange you can slip paper through the gap. I guess they will eventually settle over time (only a few mm in it) but is that going to crack plaster or tiles something once decorated? Should it be shimmed or something?
Nickfromwales Posted February 19, 2023 Posted February 19, 2023 (edited) Cut hardwood shims and smack them in until they won't smack any more Make the shims for each gap, in a large mitre saw, and have the open gap as the start size of the shim, and then the shim doubling in thickness over the depth of the purchase point. Apply some resin based wood glue to the two mating timber faces, immediately prior to fitting them, and job's a good 'un Edited February 20, 2023 by Nickfromwales bold bits added 3 2
George Posted February 20, 2023 Posted February 20, 2023 This is why I prefer mechanical connections like joist hangers. Any way of getting a small angle/cleat attachment to connect the joists to the beam?
Nickfromwales Posted February 20, 2023 Posted February 20, 2023 3 hours ago, George said: This is why I prefer mechanical connections like joist hangers. Any way of getting a small angle/cleat attachment to connect the joists to the beam? Waste of time, imho. Shims are perfect for this, cheap as chips and easy to DIY.
