HughF Posted February 12, 2023 Posted February 12, 2023 (edited) I’m a 16mm mlcp kinda guy and am tooled up to press this and copper. Any benefit of using an mlcp radiator tail (pre bent, single joint under the floor) instead of a bent length of 15mm and a straight coupler under the floor? The only benefit I can see is there’s one less press joint. But the 16mm rad tails are close to £10 each, vs £2.50 for an M to U female/female press adapter. The benefit of using a straight adapter is I can make the 15mm hockey stick long enough to do TBOE to bring the TRV up to a more accessible height. Can’t do that with a pre-bent 16mm tail. Edited February 12, 2023 by HughF
HughF Posted February 20, 2023 Author Posted February 20, 2023 I went for adapters in the end, much cheaper…
