eandg Posted January 26, 2023 Posted January 26, 2023 In #37 of plans that didn't quite go to plan, I have 280mm from the top of my underbuild (two courses of blockwork, the top of which meets the external ground level to build up) to the underside of the three external doors. Should I just have the facing bricks under the doors cut by 20mm horizontally or is there a better solution - presumably 5mm mortar for the bottom courses won't cut it and would be odd looking even if it did?
