Hi All,
I am in the process of putting together a project plan to renovate our house. As part of it I am strongly considering a Solar Array on a south facing roof. This roof faces a highway in a conservation area. It must be noted a property close by has solar and falls within the conservation area also.
My main question is how much hassle is it putting a planning application together. I have a thousand different things to work on to do with the project itself, I am wondering whether a planning consultancy would make my life much easier.
Thanks In advance for any advice.
You'd just need a streetscape type drawing and some photos and a brief design and access statement. By default, you can't have PV panels on the street side in a conservation area. You should preempt the visual impact by using an in-roof tray system and giving example photos. That's how we did it and it didn't even raise any questions.
Planning Portal says this:
All the following limits must be met:
  • Panels should not be installed above the highest part of the roof (excluding the chimney) and should project no more than 200mm from the roof slope or wall surface.
  • The panels must not be installed on a building that is within the grounds of a listed building or on a site designated as a scheduled monument.
  • If your property is in a conservation area, or in a World Heritage Site, panels must not be fitted to **a wall** which fronts a highway." (My emphasis).
This seems to me to imply that they are (may be) PD on a **roof** fronting a highway. This apparently does not stop my LA discouraging  PV on the front of properties in conservation areas. I am sure this will hinge on individual interpretations of 'so far as is practicable' (below). My memory says that some years ago PD rules *did not* allow PV on front roofs in CAs but as far as I remember that changed (probably somewhere around 2010) to the current position.
See GPDO Part 14 A.1 and A.2.
https://www.legislation.gov.uk/uksi/2015/596/schedule/2/made
Conditions
A.2  Development is permitted by Class A subject to the following conditions—
(a)solar PV or solar thermal equipment is, so far as practicable, sited so as to minimise its effect on the external appearance of the building;
(b)solar PV or solar thermal equipment is, so far as practicable, sited so as to minimise its effect on the amenity of the area; and
(c)solar PV or solar thermal equipment is removed as soon as reasonably practicable when no longer needed.
