rich1899 Posted January 31, 2023 Share Posted January 31, 2023 20 hours ago, Russdl said: No. I plan on doing it under Permitted Development. Have I missed something vital? From all I’ve read I don’t see that I need planning for the proposed garage. Don't quote me, but on checkatrade it states the following: Permission to build a garage? Well, this will depend on a few factors, but generally, no, you won’t need planning permission to build a garage. Garages are usually considered as outbuildings and don’t need planning permission. Of course, there are exceptions to this rule. If you want to avoid needing planning permission, ensure your garage: Has a floor space of below 15m2 if freestanding or 30m2 if attached to your home. Isn’t used as a living space. Isn’t higher than 4 metres. Takes up less than half of your land. Is only one storey high. If your garage falls outside any of these regulations, you’ll likely need to apply for planning permission before building commences. Copyright Checkatrade. Using this information in an article or blog? https://www.checkatrade.com/blog/expert-advice/planning-permission-garage/ I'd like to know if these facts are true also. Link to comment Share on other sites More sharing options...
Russdl Posted January 31, 2023 Author Share Posted January 31, 2023 @rich1899 I think that’s incorrect. Here’s the guff from the Planning Portal. 2 Link to comment Share on other sites More sharing options...
