SEAUNE Posted November 16, 2022 Posted November 16, 2022 project fitting 40kw pv solar panels to barn and installing 3phase invertor staying totaly off grid battery backup systems will be fitted at a later date i welcome all thoughts and comments using a trina solare 425 panel (102) of them in total with a hybrid invertor (not chosen yet) input welcome on invertors will need to be able to ev charge , battery charge,
Nickfromwales Posted November 16, 2022 Posted November 16, 2022 Welcome, fellow welsh person ! EV charging is a challenge, as you’ll be at 7kW max, with that needing to be sustained. Have you ruled out a diesel genny?
SEAUNE Posted November 16, 2022 Author Posted November 16, 2022 i already have a genny back up system if needed but the cost would be high to run i am on grid with a 3 phase with a 100 kva supply and as you can imagine cost are high hence the reason for adding a helping system of pv 40kw 3 phase is a substantial input into reducing cost from 40 kw i would estimate through the winter time i may get 30 -50 % input from the panels can you explain what you mean by 7kw max with regards to ev alough i don t expect to be totaly off grid all the time and having the ability of the grid input my energy bills should be dramaticaly reduced on a monthly basis
