DLES1966 Posted November 2, 2022 Share Posted November 2, 2022 Can anyone assist with what details to add to the G83 form, please? Specifically what information did you put in the ... 1 - "Final copy of circuit diagram" - did you draw out a diagram of location or a wiring diagram? Any example would be good Does this need to be a full electrical drawing or something pretty? Link to comment Share on other sites More sharing options...
Dillsue Posted November 2, 2022 Share Posted November 2, 2022 Its a G98 notification that you should be using as G83 was superseded a few years ago!! The drawing they likely want is a single line diagram showing how the principle components in your house are connected. If you get an A4 sheet of gridded paper its easy enough to draw showing each component as a box with a description in the box or next to it. Show the cabling between each box as a single line. One of the principle things they want to know is the location of the PV isolators so add a note next to the isolator boxes stating where the isolators are. Google "PV single line diagram" for some examples, but keep it simple! 1 Link to comment Share on other sites More sharing options...
