Gina_Violet Posted October 26, 2022 Posted October 26, 2022 Hi, I am looking at replacing my log burner which uses the house chimney with a pellet stove. I have explored online and I'm rather confused by it all. Can pellet burner just use the existing chimney? I just wondered what was involved and needed. It would be one without a boiler, so just a stove. Thank you.
PeterW Posted October 26, 2022 Posted October 26, 2022 Pellet stove needs a standard chimney or liner suitable for a wood burning stove so if the chimney is in good condition then you will be fine. 1
Gina_Violet Posted October 26, 2022 Author Posted October 26, 2022 Thanks, apparently the chimney is fine as we had it swept today. Although some insulation roll came out the chimney which I thought was a bit concerning.
