soapstar Posted November 7, 2022 Author Share Posted November 7, 2022 13 hours ago, j_s said: Any luck with the other areas you were fixing? Started to focus on the external door in the Utility - managed to fit up a thermal door curtain to cover the door at night. Tested this last night and to be honest the temperature did not change very much (perhaps felt less chilly whatever that means!) Need to get on with filling the cavity around the sink waste water pipe next and see if that fixes anything. Our house is controlled via Neostat thermostats..upon doing some reading it is not uncommon for these to be incorrect and require calibrating. Right enough the laser thermometer does seem to be around 1.5 degree warmer than the display, although this is quite dependant on where you take the reading. This has been covered in another thread so wont go into it too much but these thermostats seem to lack proper airflow to allow them to measure the correct temp...although I checked the others in the house and these seem pretty spot on. I may look into re-calibrating the utility thermostat and take it from there... Link to comment Share on other sites More sharing options...
