learner Posted October 5, 2022 Posted October 5, 2022 Hi. Can you recommend a smartlock for a gate between the street and courtyard that does everything. I want a camera with mic and unlock buzzer. I want finger print, fob, key and phone entry. I want the camera to be able to plug into a pc screen that my cctv is running above front door, eg I don't want second screen. Any advice please
Carrerahill Posted October 5, 2022 Posted October 5, 2022 2 minutes ago, learner said: Hi. Can you recommend a smartlock for a gate between the street and courtyard that does everything. I want a camera with mic and unlock buzzer. I want finger print, fob, key and phone entry. I want the camera to be able to plug into a pc screen that my cctv is running above front door, eg I don't want second screen. Any advice please Paxton do systems like this -would be pricey, I would look here: https://doorcontrolsdirect.co.uk/20-access-control or similar for the bits you need. A video door entry with finger & fob is easy enough. You say key, that would usually be done via using ironmongery which also allows key on a solenoid receiver as a mag lock will hold the door shut and cannot be override with a key. As for combining the CCTV you would need an output from the door entry onto your HVR/monitor system which is fine. Or a door entry unit with a standalone CCTV output you can incorporate into your CCTV system.
