Richie81 Posted August 20, 2022 Posted August 20, 2022 Hello, I had a dry ridge fitted last November. I have just had some lads come round and reattach a bargeboard that had come loose and they have told me that the dry ridge has been fitted incorrectly. They say that the waterproof membrane isn't stuck down to the tiles correctly. They took a photo and showed me that the membrane is loose, they said that water can get in underneath the membrane. Should the self-adhesive strip be stuck down to the tiles? Will this cause water ingress if it isn't stuck down properly? Attached is a photo (the best I could get). Some of the membrane looks to be stuck down fine other bits look loose from the photo. Thank you,
nod Posted August 20, 2022 Posted August 20, 2022 Don’t answer the door the next time they come round It’s unlikely that driving rain em will get under that 1
Richie81 Posted August 20, 2022 Author Posted August 20, 2022 Thank you, that has put my mind to rest a little bit. 😀 1
nod Posted August 20, 2022 Posted August 20, 2022 30 minutes ago, Richie81 said: Thank you, that has put my mind to rest a little bit. 😀 No Joking apart those  figures are amazing The household  bills should be a fraction of what they are now for Scotland 1
