Carpe Diem Posted July 25, 2022 Share Posted July 25, 2022 Hi, I am building a property and there has been a change to the design which means that a foul water access point that has already been installed is not going to be internal in the property - its a link between the garage and utility which is now to be enclosed. Is this allowable? Its obviously not ideal, but the alternative is a huge amount of work and potentially not even possible. Link to comment Share on other sites More sharing options...
Temp Posted July 25, 2022 Share Posted July 25, 2022 (edited) You mean it is now going to be indoors? That can be allowed but you need a different cover for it and approval from the BCO. Example.. https://www.kentstainless.com/access-covers-manholes/tiled-resin-floor/solo-industrial-manhole/ https://www.drainagepipe.co.uk/manhole-covers-internal-use-c-282/ Edited July 25, 2022 by Temp Link to comment Share on other sites More sharing options...
Carpe Diem Posted July 26, 2022 Author Share Posted July 26, 2022 Yes, I meant it will be indoors. thanks for the links Link to comment Share on other sites More sharing options...
