I am very interested in the views of the knowledgeable people here, because I am very excited about this project, but mistakes are expensive.  I am engaged on renovation  (although it's basically a rebuild apart from the slab).
Any advice/opinions gratefully received, and in particular
- do I NEED mixer valves if I can set boiler flow to 50 and use a motorised valve?
- can I get away with ambient sensors, and not have to embed some in the floor itself?
- since I am computer controlling, I can easily arrange it so the boiler only runs if one of the MVs is open.   But belt and braces, the Bathroom towel rail is a bypass loop IF I OMIT the TRV.   Do I need to do that?
Thanks, peeps - really look forward to hearing from you.
OTHER INFO
-   total floor area ~ 180 sq metres, and insulation will be to at least latest building regs.
- retaining existing 24Kw condensing combi with built-in bypass valve
- MVHR system
- 4 zones UFH, + Bathroom Towel Rails + (possibly) 2/3 rads
- computer controlled (I have the skills to do the software and  electrical part of that)
- floor coverings vinyl/carpet/engineered wood.
The idea of Mixer Valves in inconvenient places gives me the vapours ... ideally, I want everything in the plant room with the boiler.  So here's my plan...
1.  Set the Combi flow temp to 50 (hoorah - we'll be condensing and save gas)
2.  Use 2 port Motorised Valves (computer controlled) for UFH zones (all in the plant room) - increased pipe lengths but simpler and neater
3.  Simple unswitched (no MV) zone to bathroom towel rail with TRV
3.  Ambient temperature sensor in each Zone
Yes as 50°C is too high for UFH
Yes
Most controllers do that now - use the self balancing actuators from Salus and save yourself a lot of issues.
No you won’t as condensing is a function of return and flow not just flow temperature.
Expensive and pointless - use a manifold and actuators.
What happens when TRV closes and blocks the flow while the pump is running ..??
Peter - thanks for the response ....
  • Interesting - what flow temp would be OK?
Yes
Cool - no issues with lag?   Expect UFH above 120mm insulation, then vinyl or carpet
Those look interesting.   Thanks
I see your point.   So it's actually a function of load/demand i.e. which parts of the system are actually live, and thus increasing the diff between flow/return.   Hadn't spotted that.
Very possible - I clearly need to spend a bit more time understanding actuators.
Is that not what the bypass in the combi is for?
