ashthekid Posted May 17, 2022 Posted May 17, 2022 Can I check whether changes to the new building regs in June will apply to my project that I already started 18 months ago or do they only apply to projects started after June 2022 when they come into enforcement?
DevilDamo Posted May 17, 2022 Posted May 17, 2022 It will only affect all new BR applications registered on or after 15th June.
Temp Posted May 25, 2022 Posted May 25, 2022 I watched this YouTube video today and in here he mentions that if you have already submitted you have to finish the build by June 2023 or comply. See from 1min in.. 1 1
DevilDamo Posted May 25, 2022 Posted May 25, 2022 @Temp Correct. So to design and build to the current BR’s, an application needs to be submitted before 15th June 2022 and works started before 15th June 2023. Not complying with both of those means adhering to the new BR’s. 1
Temp Posted May 25, 2022 Posted May 25, 2022 1 hour ago, DevilDamo said: @Temp Correct. So to design and build to the current BR’s, an application needs to be submitted before 15th June 2022 and works started before 15th June 2023. Not complying with both of those means adhering to the new BR’s. OK that makes more sense. In the vid he suggests it has to be finished by 2023.
DevilDamo Posted May 25, 2022 Posted May 25, 2022 3 hours ago, Temp said: OK that makes more sense. In the vid he suggests it has to be finished by 2023. Just incase it’s asked or confusing for others and it’s the paragraph on the second page.
dabba Posted July 14, 2022 Posted July 14, 2022 Can someone please advise regarding the new regs, Looking at the text for transitional Arrangements It states if building notice or full plans application or initial notice have been subitted before 15th June 2022 then ok with the older arrangements, as I have full plans submitted and passed with local authority prior to June 15th will I be ok with the plans and calc's submiited?
Temp Posted July 14, 2022 Posted July 14, 2022 6 hours ago, dabba said: Can someone please advise regarding the new regs, Looking at the text for transitional Arrangements It states if building notice or full plans application or initial notice have been subitted before 15th June 2022 then ok with the older arrangements, as I have full plans submitted and passed with local authority prior to June 15th will I be ok with the plans and calc's submiited? Yes. Just be sure to start work before June 2023. See above. 1
dabba Posted July 17, 2022 Posted July 17, 2022 Checked with local Buiding Control they are saying regardless of the full plans being deposited and passed pre June 15th 2022, they say the bulilding regs had also to be submitted before 15/06/22. I'd be grateful if I get some some clarification from the forum please.
