Bsil Posted May 17, 2017 Share Posted May 17, 2017 Good morning all,We have been checking out (the many) bath options there are out there, and trying to narrow our choices down. We are weighing the pros and cons of steel vs acrylic, and it seems as long as we go for thicker ones, then either material will be durable. We've been looking in particular at Trojan (acrylic - 5mm and 8mm) Trojancast Kaldewei (steel 3.5mm) Carron (5mm) We're looking for one around £100-300 price range. This is probably a very common topic, but we would really like to get some advice from any plumbers / fitters out there. Any advice or other suggestions about your (good or bad) bath experience are welcomed.Thanks in advance Link to comment Share on other sites More sharing options...
Guest Alphonsox Posted May 17, 2017 Share Posted May 17, 2017 We fitted a Trojancast bath to our current house - Extremely solid. We have fitted similar to the new build. If you can get one within budget then I would definitely recommend one. EDIT - And welcome to the forum BTW Link to comment Share on other sites More sharing options...
ragg987 Posted May 17, 2017 Share Posted May 17, 2017 Have no experience of the others, but Bette are similar to Kaldewei and cheaper. megabad.com Had an acrylic in previous houses - probably a bias but I avoid as feel flimsy and tendency to flex and move. Link to comment Share on other sites More sharing options...
