mattchan Posted April 24, 2022 Posted April 24, 2022 I have some cables that have been attached to a brick wall with upvc capping. The original plan was to float and set the wall, now it has to be covered in 37.5mm thick insulated plasterboard that will be attached with adhesive foam. Thermally the worst case is the capping in direct contact with the foam. What reference method for cable derating should be used in this construction?
nod Posted April 24, 2022 Posted April 24, 2022 I definitely wouldn’t use foam Use drywall adhesive You can bridge The camping’s
mattchan Posted April 24, 2022 Author Posted April 24, 2022 Whats the campings? Is drywall adhesive foam bad stuff?
nod Posted April 25, 2022 Posted April 25, 2022 6 hours ago, mattchan said: Whats the campings? Is drywall adhesive foam bad stuff? 😂caping
