Porthole Posted March 12, 2022 Share Posted March 12, 2022 Hi - be really grateful for some advice on this. We've had screed laid close to our newly installed sliding doors but there is a gap in the screed between the screed and frame of sliding doors. Please can someone tell me what should be used to fill the gap. Also should the insulation be removed. There are packers upon which the cill of the doors sit which means the dpm can't sit flat on the concrete below, so not sure how it should all be done. The image is taken from directly above with packers sitting on a concrete base. Hope that makes some sense. Link to comment Share on other sites More sharing options...
PeterW Posted March 12, 2022 Share Posted March 12, 2022 What will the final floor finish be ..? Link to comment Share on other sites More sharing options...
Porthole Posted March 13, 2022 Author Share Posted March 13, 2022 13 hours ago, Porthole said: Hi - be really grateful for some advice on this. We've had screed laid close to our newly installed sliding doors but there is a gap in the screed between the screed and frame of sliding doors. Please can someone tell me what should be used to fill the gap. Also should the insulation be removed. There are packers upon which the cill of the doors sit which means the dpm can't sit flat on the concrete below, so not sure how it should all be done. The image is taken from directly above with packers sitting on a concrete base. Hope that makes some sense. It will be porcelain tiles Link to comment Share on other sites More sharing options...
