Johnsom Posted February 28, 2022 Posted February 28, 2022 Hi all Need some guidance please i want to convert the loft into room ,mainly for storage but would like it to be safe A bit worried that Iam using the correct materials and to spec. is it worth getting plans done ? would this tell me what thecorrect materials to use ? I would like to remove the tresses to make more room thanks in advance
markc Posted February 28, 2022 Posted February 28, 2022 30 minutes ago, Johnsom said: Hi all Need some guidance please i want to convert the loft into room ,mainly for storage but would like it to be safe A bit worried that Iam using the correct materials and to spec. is it worth getting plans done ? would this tell me what thecorrect materials to use ? I would like to remove the tresses to make more room thanks in advance Removing trusses or any timbers in a loft is serious and needs Structural Engineer input. simply boarding a loft is pretty straight forward, opening up spaces is rarely easy and often very expensive
