Joe87 Posted January 23, 2022 Posted January 23, 2022 Hi all, Probably a silly question. Should i cut my fascia board to match the pitch of my flat roof? If so how do i go about this? I was planning on having the bottom level all the way across the side and then scoring the inside top of the fascia board in line with the pitch of the roof and cutting along with a circular saw to get the shape? So the fascia would be the same level across the bottom and go with the pitch along the top. Kerb trims etc would be added then to finish off. If i did this im assuming id have to get a smaller width fascia board for the back of the building to line it up with the side fascias? Thanks for any help.
ToughButterCup Posted January 23, 2022 Posted January 23, 2022 A diagram would help ..... There is more than one way of visualising your description.
