phloaw Posted December 12, 2021 Posted December 12, 2021 (edited) Hello, this is a house in UK, built in the early '70s. Some parts of the outer walls are made of concrete blocks. I suppose they are one of the usual types: e.g., aggregate, lightweight or aircrete, but I'm not sure which one. I would like to know in order to buy the appropriate anchors/fixings. Any suggestion/input welcome. Their size is approximately 44.5x22cm, they have no identifying signs or marks visible. I attach pics. TIA Edited December 12, 2021 by phloaw clarify
saveasteading Posted December 12, 2021 Posted December 12, 2021 Blocks are standard sizes. What kind of fixing are you considering and for what purpose?
phloaw Posted December 12, 2021 Author Posted December 12, 2021 3 minutes ago, saveasteading said: Blocks are standard sizes. What kind of fixing are you considering and for what purpose? Thanks. I need to hang a radiator on a dot and dab wall in the same house, and the blocks are the ones showed here. Need to decide what fixings.
saveasteading Posted December 12, 2021 Posted December 12, 2021 There are good fixings that will hold to the plasterboard, or you can use long screws to the block. I would trust the plasterboard, just use plenty of fixings in case someone sits on the radiator. There are all sorts of fancy fixings but I would just use plastic wall-plugs, and plenty of them as the brackets have several holes. BUT pay the little bit more for a known branded make. 1
phloaw Posted December 12, 2021 Author Posted December 12, 2021 4 hours ago, saveasteading said: There are good fixings that will hold to the plasterboard, or you can use long screws to the block. I would trust the plasterboard, just use plenty of fixings in case someone sits on the radiator. There are all sorts of fancy fixings but I would just use plastic wall-plugs, and plenty of them as the brackets have several holes. BUT pay the little bit more for a known branded make. Thanks. I'd still like to know whether those blocks are standard breeze blocks (aka aggregate) or aircrete (aka thermalite). Any guess?
saveasteading Posted December 12, 2021 Posted December 12, 2021 Standard concrete by the looks of them. Easy to check with a chisel or drill, as concrete is very hard and thermalite etc is made from a paste, looks like grey aero underneath and turns to dust under a hammer or chisel. 2
