We are going to install UFH.  For the most part this will be in areas where there are wood floor joists.  We will of course be putting insulation between the joists.  We will be laying glue down LVT.  This has to be laid on special 5.5mm plywood sheets which have to be laid within certain level tolerances.
What are the options as regards installation methods for the UFH pipe work ?
1 hour ago, PeterW said:
Ideally need to use spreader plates - are these new joists or is this a retrofit..?
It’s a mixture of retrofit and new.   I’ve read mixed reports of the effectiveness of spreader plates so I don’t know what to think of them.
