Hi,
I'm opening up a door way in an external gable wall and replacing the existing lintel with a longer one. The wall is non-load bearing, the first floor joists and the roof trusses run parrallell to the wall and it's a bungalow.
Do i need to do anything other than support the wall with Acrows and strong boy's from both sides? I can't support the wall on the floor joists obviously.
Thanks in advance
