I have a really tight Velux install between a hip and the jack board of a valley.. the window will literally be sitting above the jack board with the flashing down approx 100mm into the a 200mm valley.
It has been mentioned that I may have a problem if it snows?  Anyone foresee any other issues with this? Also one of the top corners is going to go tight to a ridge tile, so I am going to have to cut the top of the flashing to fit under the ridge tile on the hip. Again , prob not the best idea but does anyone think its an absolute No no . Doesn't help that the flashing is so tall on the top . I don't have an option to move the window, and its the smallest Velux I could get CK 01.
Smaller size would defo help , but as you say.. not sure about quality.
I suppose you know what you're getting with Velux, plus I've already purchased.
Might just see how it goes
