What to do with this mess of a concrete sill?
I’ve just had a new window put in, and was checking underneath for a draft.
Ive found the concrete-precast sill has no DPC or much of anything behind it.
There was a load of bricks just chucked in the gap, prior to photos.
The external building is a rubble-stone barn conversion, all done in lime.
what should I do, back fill the sill with lime mortar, to try and minimise water ingress?
no way of getting a DPC in.
If it needs no more structure, I'd fill it with EPS, hopefully from a single offcut shaved to shape - possibly foamed in to fill the gaps.
Or polybeads in a mixture with a bit of PVA, so they stick together and don't fly out again.
The important thing is to vanish the cold bridge.
Or you could make a secret compartment with a lifting lid.
