learner Posted October 17, 2021 Posted October 17, 2021 I have used 3 colour types of wood preserver on my shiplap cladding and i think it looks great. It has a very matt finish which it want to keep but want to protect it and make it slightly glossy, maybe eggshell?? Is there a product to finish the cladding that would do this? I may be forced to paint the whole thing white in the future.
saveasteading Posted October 17, 2021 Posted October 17, 2021 Have a look at the known names for stain, like Sadolin. Get a small sample tin and try it . I have used it several times on new cladding and the subtle sheen has been very pleasing. How it works on older wood I don't know, but my hunch is it will be good. In my experience this keeps its looks for 10 years on the sunny side, and longer on the other faces. If you use the oak finish on pine, there is very little change but then it stays that colour instead of changing to grey. Darker colours last remarkably well too.
learner Posted October 18, 2021 Author Posted October 18, 2021 My Barrettine preserver has coloured the new pine cladding nicely. Its the protection i need to finish. Wax? Varnish? Poly? Shalack? Also it has just rained on my new work, how many days before i can add second coat of the preserver??
saveasteading Posted October 18, 2021 Posted October 18, 2021 1 hour ago, learner said: Its the protection i need to finish. Wax? Varnish? Poly? Shalack? I don't know Barretine but I see that it is a stain and preserver. I think you want a sheen, rather than any more protection. If it dries to matt and you want a sheen then you will need something on top. However this will need to have good resistance to the weather as it becomes your outside layer. All I can suggest is 1. see what it says on the tin. 2. go to a paint merchant and ask for advice. 3. put another coat on, but of clear "stain" for want of a better term, that does produce a sheen. 4. let us know your solution and how it works out.
learner Posted October 18, 2021 Author Posted October 18, 2021 I bought this. Ill let you know how it goes. Osmo UV Protection Oil Extra 420 Clear Satin
saveasteading Posted October 18, 2021 Posted October 18, 2021 OUCH the price!. £60 for 2.5litres. That should be good then. Good luck.
learner Posted October 18, 2021 Author Posted October 18, 2021 I thought the same but id rather have the expensive stuff as im not a pro. Hopefully 2 cans will do the job for the next few years and that'll be quite good value
saveasteading Posted October 19, 2021 Posted October 19, 2021 16 hours ago, learner said: id rather have the expensive stuff as im not a pro The pro's prefer the expensive stuff generally. Whether £20 or £200 for 5 litres it still takes a lot of labour. and the better paint lasts as least twice as long.
