Hi,
Im new to the site: Stumbled across it when trying to resolve my querry.
Does anyone know how to account for low emissivity cavities in U-Value calculators? I'm using the BRE calculator, trying to calculate yhe U-Value of the following timber frame closed panel build-up:
  • 12.5mm Plasterboard
  • 35x50mm vertical battens to create a service cavity
  • Reflective AVCL layer
  • 25mm PIR Insulation
  • 38x89mm timberframe studs at 600mm centres, with 100mm lambda 0.044 insulation between the studs
  • 9mm OSB
  • Reflective breather membrane
  • 50mm Cavity
  • 102.5mm brick
I come up with the calculation below, but it seems to me that the reflective membranes on the inner and outer cavities have a far to large impact on the calculation?
Walter V
