Garage conversion into utility room
Abeer khan
I am near to starting a garage conversion.  However I am receiving different / confusing information with regard to the stud walls and a Vapour Membrane.
Q - Is the vapour membrane attached to the stud work on top of the insulation on the inside of the building before I plasterboard or is the VM attached to the stud work on brick side of the stud.
I also intend to insulate the roof of the garage,
Q - when I do insulate do I make an air gap or is the insulation pushed up tight to the OSB underside of the garage roof then attach a membrane before I plaster board ?
Any advice would be appreciated,  thanks in advance.
