Can’t figure is it leak or condensation
I have retightened olive with  ptfe  tape on olive
left it couple of hrs rechecked water ,
retightened again will check again in about 12 hrs & let kno
here’s the nut picture that collect water on top only
bottom nut bone dry
If you wrap some kitchen roll around the pipe and leave a gap above the nut …if the paper gets wet the water is condensate or leak above, if paper stays dry it must be from the nut or olive.
Over tightened olives are difficult to seal because the pipe may have collapsed or even split under the olive.
If it’s not split or broken completely then jointing paste can work when PTFE wont
Edited by markc
