Hello, we are planning for a polished concrete floor. I had a question as to whether the subfloor slab is required or not, as we'll already be laying 100mm of concrete at the top...
  • 100mm polished concrete (poured over UFH pipes)
  • Vapour control layer
  • 200mm EPS insulation
  • DPM
  • 100mm concrete subfloor slab --> Do we need this? If we are pouring concrete as the final layer, is the subslab needed?
  • Hardcore
There was a similar thread last week regarding this.
I personally can’t see the point in double slabs if the ground is good and compacted hardcore is there.
bbut if I remember correctly one or moreBCO’s had wanted the sub slab
