garrthwatts Posted August 2, 2021 Posted August 2, 2021 Cove forming vinyl round floor corners typically runs up the the top of the skirting board, but can it be run all the way up the wall in one uninterrupted continuous strip ?
Mr Punter Posted August 2, 2021 Posted August 2, 2021 No reason why not. You will need a more complicated mitre in the corner. What is going on the wall?
garrthwatts Posted August 2, 2021 Author Posted August 2, 2021 That's good to know. But why would the mitre need to be more complicated, I am looking for the same finish, only without the cap at the skirting level. Is the flooring held in place with tension thanks to the skirting cap, or is the vinyl glued ?
Mr Punter Posted August 2, 2021 Posted August 2, 2021 10 minutes ago, garrthwatts said: But why would the mitre need to be more complicated Because you have a curve in the corner instead of a right angle?
garrthwatts Posted August 2, 2021 Author Posted August 2, 2021 I was under the impression that "cove forming" was just that, a rounded corner like in hospitals. When laid down, the floor is seamless, and I would like to keep that for the walls. Assuming that the room is without intricacies that require cutting, can the walls be seamless as well ?
