fiaraziqbal Posted June 27, 2021 Posted June 27, 2021 Good morning all, I am part way through teh build of a log cabn and for water supply i was looking at connecting a caravan pump to hep20 pipes etc. has anyone tried this and what would your advice be? as iam thinking that the variation in p ressure may not be "healthy for tehhep20 system. additionally any pipe recommendations? Thanks all
Galileo Posted June 27, 2021 Posted June 27, 2021 Seen plenty of motorhome builds including my own one using HEP20, a log cabin will just vibrate less at speed. With a maximum permanent operating pressure 12 bar at 20º, you're safe using a caravan pump with HEP20. Key is to install an accumulator and use a pressure sensing pump, that way you won't get pulsing and spluttering at the taps and the pump will behave better at sensing pressure drops. https://www.surejust.co.uk/5-litre-accumulator-tank (for example, size to suit)
fiaraziqbal Posted June 27, 2021 Author Posted June 27, 2021 30 minutes ago, Galileo said: Seen plenty of motorhome builds including my own one using HEP20, a log cabin will just vibrate less at speed. With a maximum permanent operating pressure 12 bar at 20º, you're safe using a caravan pump with HEP20. Key is to install an accumulator and use a pressure sensing pump, that way you won't get pulsing and spluttering at the taps and the pump will behave better at sensing pressure drops. https://www.surejust.co.uk/5-litre-accumulator-tank (for example, size to suit) Thank you for that, time to get plumbing!
