Ryan Bazeley Posted June 9, 2021 Posted June 9, 2021 Can someone please help me? The waste pipes that are cast in my slab out to the sewer pipe are 110mm. I have noticed on my plans that BC have stated I should use a 200mm pipe! I will have 3 bathrooms which will all drain into the one stack, would that be the reason they say 200mm? I can change it if necessary but do I need to? Thanks
Ryan Bazeley Posted June 9, 2021 Author Posted June 9, 2021 IGNORE THIS, I AM AN IDIOT!! It was a 200mm radius bend ? 2
Temp Posted June 9, 2021 Posted June 9, 2021 +1 In case it helps... you should put larges radius "rest" bends at the bottom of stacks.
