We have some fairly hefty beams in our build and discovered that a 305 high I beam may in fact be much higher than 305 when delivered! As the weight per meter increases so can the height. I didn't believe this at first but the supplier sent me a copy of his steel tables. 305 beam at 240kg/meter came in at 350 height. Can work around it OK but could have been a drama if this happens in a bad place!
