Reviewing kit drawings and the manufacturer has allowed for 882mm openings which I'm presuming is sufficient for an 826mm wide door (will confirm when I go back with comment). They only provide internal load bearing walls and I am just finalising positions. In an ideal world I would be shifting the door a little bit from the preliminary drawings to ensure kids' bedrooms are the same size, which would allow only 1045mm for the door (as per sketch below). Is that sufficient?
