eski701 Posted May 5, 2021 Share Posted May 5, 2021 Hi I am involved with a community build of a first floor room which has never been finished as they ran out of money but now we are trying to fund raise to finish it off that will eventually be used as a youth club. At present I have a rough cast concrete floor approximate area is 150m2 , from there to the Finished floor level I have apx 85mm In that 85mm I need to fit wet UFH system specified at present with 16mm pipe. & a LVT ( maybe Karndean ) finished floor apx 5mm thick. As the room is being used as both a social youth space and a conference room I need to make sure its got some acoustic properties as well as being strong to take 60 – 100 people. So we are looking for a solution that will work for this particular scenario, if using acoustic battens they would have to be with cradles to take up the uneven floor and potentially spaced at 400mm with 2mm chipboard ontop to take the loading . Any help you can suggest would be greatly received Many thanks Chris Link to comment Share on other sites More sharing options...
Dudda Posted May 5, 2021 Share Posted May 5, 2021 I'd probably put down 20-30mm of insulation and then a self leveling liquid screed with UFH in it. Then a good quality vinyl with acoustic properties. I don't know Karndean but you want a vinyl with good acoustic properties. eg https://www.forbo.com/flooring/en-ie/products/acoustic-flooring/sarlon-19-db/sarlon-19-db-wood/bvialm The noise in the room will be from the people chatting, shouting, laughing, etc. It's not really the floor that will cause noise in this case. You'll need sound absorbing materials either with lots of fabric in furniture or panels fixed to the ceiling and walls. These can be either expensive acoustic panels or cheaper home made DIY attempts or a mixture of both. Carpet would help acoustically but I think you need something like a vinyl that's easy to clean. A timber floor build up will add to the acoustic issues compared to a liquid screed. Link to comment Share on other sites More sharing options...
