Prior Approval and PD
Hi all,
Hope you're well. I've just joined the forum and appreciate the excellent forums on here.
I've got a situation with my house that I was hoping some of you could help me with. My house is a 1930s semi in London. In 2007 the house had some additions put on it as below:
A. Dormer Loft - 36 cubic meters
B. Side extension of the pre-existing side extension wall (as built in 1930). 3m out and 2.7m wide.
Both of these were done with a Certificate of Lawfulness application and approved.
C. Rear extension from the rear main wall of the property extending 3m out and 4m wide.
This was done via a planning application and was approved.
The total width of the house is 6.7m. I have the following points I need some guidance on and which I am struggling to properly understand:
1. Can I extend C to 6m - based on the Government now allowing terrace/semis to extend to 6m from the main rear wall.
2. Can I widen B to 3.3m.
I appreciate my neighbours would have to be consulted, but I wanted to know if it's even worth pursuing before I start engaging architects and the LA planning dept.
Many thanks in advance for all your help.
help - @jack
? Gem
