Geminiuk01 Posted April 1, 2021 Posted April 1, 2021 Hi all, Hope you're well. I've just joined the forum and appreciate the excellent forums on here. I've got a situation with my house that I was hoping some of you could help me with. My house is a 1930s semi in London. In 2007 the house had some additions put on it as below: A. Dormer Loft - 36 cubic meters B. Side extension of the pre-existing side extension wall (as built in 1930). 3m out and 2.7m wide. Both of these were done with a Certificate of Lawfulness application and approved. C. Rear extension from the rear main wall of the property extending 3m out and 4m wide. This was done via a planning application and was approved. The total width of the house is 6.7m. I have the following points I need some guidance on and which I am struggling to properly understand: 1. Can I extend C to 6m - based on the Government now allowing terrace/semis to extend to 6m from the main rear wall. 2. Can I widen B to 3.3m. I appreciate my neighbours would have to be consulted, but I wanted to know if it's even worth pursuing before I start engaging architects and the LA planning dept. Many thanks in advance for all your help. help - @jack ? Gem 1
