Job Posted March 29, 2021 Share Posted March 29, 2021 Hello, new to the forum, and hoping to find a place to get advice and tips with timber frame building. Living in Belgium, I'm making plans for an addition to our house, including a first floor level, over the addition and part of the existing house. At the moment sketching and figuring out what I want before getting in touch with an architect (required in Belgium...) I am wondering about laying out the walls, and struggling to fit studs in a 16" (center-to-center) grid. How does one start a wall? Work and measure from left to right, then fill out whats left at the end? Or position the grid on center, then work towards to outside, then fill out? Is there any common practice? Easiest way? Tips? Thanks in advance! Link to comment Share on other sites More sharing options...
Declan52 Posted March 29, 2021 Share Posted March 29, 2021 Just pick a side and work from it till you get to the other end. The last gap between the two studs could be 4 inches or 14 inches. It doesn't really matter. It will just be a cut. Could be a bit shaved off a full board when your putting up the plasterboard or a tiny strip. Link to comment Share on other sites More sharing options...
Job Posted March 30, 2021 Author Share Posted March 30, 2021 Thank you Declan.. Makes my life a bit easier.. ? ? Link to comment Share on other sites More sharing options...
