regdorp Posted March 7, 2021 Posted March 7, 2021 Hi all, I've got an old commercial building that we have permitted development to convert to a dwelling. Looking at the SAP EPC requirements at the moment and wondering if you guys could help clarify a few bits please? 1) Given it is a conversion, do BC need to see anything other that the SAP EPC at the end? Or do they need to see compliance calcs etc? 2) being a conversion, I don't need to worry about achieving TER and TFEE, right? 3) The nature of the building means that every wall is a different construction method. To add to this, I'm having to Insulate with different techniques (some walls not flat enough etc), e.g. some will be on top of battens, some in/over a stud wall built inside the main wall etc. Is this combination likely to confuse anyone I use to do the SAP EPC for me? I do have the Stroma software myself and have been playing around, but some of the assumptions I'm not sure on. 4) As a conversion, is it just the U values, lighting and heating I need to worry about? For the lighting it is just ensure >75% are low energy fittings. For the heating it will be electric radiators and they just need to have programmers and thermostats to comply. Or have I missed something? Any and all help would be appreciated! Thanks, David
PeterW Posted March 7, 2021 Posted March 7, 2021 You need to read the requirements of L1B as that (assuming England/Wales) relates to conversions not new builds. https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/697629/L1B_secure-1.pdf You will need to file plans showing how you’ve met the requirement - with your build the elemental method for uValues will be easier and more appropriate. In terms of lighting - just use LED fixtures everywhere as it is easier and simpler. Fire safety will be your other main concern with a conversion - check carefully how you build up the structure. 1
