I’ve put some ply boards down between the rafters to fill the eaves space and left about an inch gap for airflow - I will then cover this gap with insect mesh (sealed and stapled).
The building in question is a 200 year old barn that’s recently received a new roof - I’m not interested in contemporary ventilation systems - plastic vents etc.
Its unconventional but I’m confident the concept is sufficient (and nicely uses left over ply)...question is how bigger gap should I leave? The more airflow the better but the less heat efficient. A 1 inch gap at 14 inches long is the equivalent to there being a square hole 3.75” x 3.75” for each rafter (14 sq inches).
My guts telling my it’s fine but I’m tempted to make the gap 1/2” bigger!
Thoughts on this? Any formulas to work this out?
Thanks in advance,
Oscar
Edited by OscarWilliams
The guidance in normal circumstances would be equivalent to 25mm continuous ventilation. So if you are leaving a gap for half of the continuous length, it would be 50mm wide.
