ollieD Posted January 19, 2021 Posted January 19, 2021 Hi all, We had masonry plans drawn up but the quotes coming back are far too high! On contacting a local timber framing company we received a much more palpable quote which they have based off the masonry plans. The floor is currently spec'd by the architect as a block and beam floor with the usual inner and outer leaves, if we continue with a block and beam floor but with a wood clad timber frame on top does the timber frame sit on top of what would be the inner leaf wall/block and beam floor or would it still sit separate on the outer leaf with some bridge between the floor and the outer wall? Does anyone have a detail specification example for the above? We have asked for the architects to amend the plan but this will obviously come with a cost that the timber frame company doesn't necessarily require. I can attach the current floor plan drawing if that helps. Any help much appreciated. Ollie
the_r_sole Posted January 19, 2021 Posted January 19, 2021 The inner leaf on either construction is your structural leaf so it's not much different up to sole plate level, I'd imagine that the timber frame company have a set of standard details which they use in the kit, it's a simple change
