OscarWilliams Posted January 14, 2021 Share Posted January 14, 2021 (edited) After some advice for a personal project, gable end is tile hung, in hindsight I probably should have put some cement board behind the battons as they cut into the window so the muck has a good surface to key to...I didn't, so If I do decide to muck the around the window It will be straight onto membrane / battons - is this likely to be an issue? Also thinking about the mortar cracking as the timbers dry out etc. Maybe i'm overthinking it. Option number two is to use soakers (I'll buy some new ones and paint them or i'll make a wood fascia to cover them). Although it's not as traditional it's probably more effective. Pros / cons of each / words of wisdom appreciated, Cheers Oscar Edited January 14, 2021 by OscarWilliams Link to comment Share on other sites More sharing options...
tonyshouse Posted January 14, 2021 Share Posted January 14, 2021 I like soakers, even made of dpc, must be welted on the inside edge no mortar I like a black or brown UPVC or finer glass ali or other metal reveal that wraps round the tiles and lines the reveal, window siliconed to this and screwed through behind that, can be fixed to window frame and offered up in one piece . warer runs down hill and doesn’t get at battens 1 Link to comment Share on other sites More sharing options...
tonyshouse Posted January 15, 2021 Share Posted January 15, 2021 If a wood lining we used to lap the soakers over front edge and copper nail them onto it dressing them round it and onto the top of the tiles, that worked well You are fortunate at the top of yours to have the eaves overhang as it gets more demanding up there usually Link to comment Share on other sites More sharing options...
