Engineered flooring over ufh screed
pauldoc
Hi, I know this has been discussed in the past but just thought I would check if there were any updates of recent installs. I am looking to lay an engineered oak floor on my under floor heated screed. Should I use an adhesive and bond it down? If so should I also use an underlay? If so what type?  also there seems to be two standard ish thicknesses of flooring, 14mm or   18/20mm. My thinking is that 14mm would transfer the heat quicker ? Any pointers much appreciated
