Hi All,
I'm restoring an 1860's farmhouse and after removing some layers I've found an inglenook fireplace. I'm trying to restore it the best I can, so I've removed all the mortar and concrete from the brick faces, replaced badly broken bricks, and grinded out the old mortar/pointing.
My question if what should I use to repoint the brickwork? I'd like to replicate the white mortar, so should I use a lime mortar or which concrete? Also, any tips on pointing would be greatly appreciated :)
Thanks!
