Cbuzz Posted November 9, 2020 Posted November 9, 2020 Noticed the control centre for the ASHP was off today, which upon checking meant the UFH wasn't working and hot water wasn't working. Trip switch in the main house circuit board is ok. The Dimplex LA6 heat pump is about 7 years old. I am having an extension built at the moment and there is a possibility that the cable could have been disturbed but is there any advice on the best way or steps to troubleshoot this. Do ASHP just 'die' normally? is there any way to check the unit to see if its that before I start pulling walls down to find the cable the circuit board. Thanks
