Brix Posted October 12, 2020 Posted October 12, 2020 (edited) I have two UFH systems in my home. One in the main house and one in the granny flat. The granny flat has 5no. zones with a timer on the combi and Wirsbo Cosy stats in each room. This is 3 wire 24V I think. I'd like to upgrade room stats to programmable stats. Upstairs each room / zone is operated on a 2 wire 240V Danfoss TP5000Si. I'd like to use something similar in the flat for continuity. Can I use the TP5000M 24 Si. Would it be a straighforward switch? Any other suggestion? Edited October 12, 2020 by Brix
Temp Posted October 12, 2020 Posted October 12, 2020 (edited) I've had a quick look at the wiring diagram for "a" Wirsbo Cosy 24V stat... https://www.uponor.co.uk/-/media/country-specific/uk/download-centre/support/manuals/legacy/cosywirsbo/cosy-wired-manual.pdf?la=en-gb&hash=B38C92FA92FB3D52591E387F7F3D06AC2A380540 and the Danfos TP5000M 24 Si. https://assets.danfoss.com/documents/DOC041186407154/DOC041186407154.pdf I think you would need a wire link in the TP5000Si but otherwise I reckon they could be used to replace the Wirsbo Cosy stats. I believe the existing stat has.. Terminal 2 → Phase 24V Terminal 3 → Switched phase Terminal 4 → Neutral 24V The TP5000M 24 Si has.. A → 0V B → 24V and relay contacts.. 1 → OFF 2 → Com 3 → ON So I think the wiring would be... Wire TP5000M 24 Si Contacts Phase 24V --------------------------- B and 2 (eg using wire link) Switched Phase ------------------- 3 Neutral 24V -------------------------- A I recommend taking a photo of the back of an existing stat before disconnecting any wires. Oh and turning off power to the whole system but that's obvious. Edited October 12, 2020 by Temp 1
Brix Posted October 12, 2020 Author Posted October 12, 2020 Thanks Temp. Was anticipating more of a yeah that'll work kind of answer. Super helpful and much appreciated!
